HOW TO CONNECT MULTIPLE FILES OF SAME NETWORK
Jawed-Sheikh
Jawed-Sheikh
Good Day Folks,
I need your help, I create multiple zone network of Storm Water of an area. Now I need to connect all of them. Seriously need your help to connect all of them to create a single network.
For Instance there is an area Phase-2 having 5 district A-B-C-D-E. and I create separately storm water now I want to create a single file to connect all these network. Any quick solution much appreciate.
Regards
Jawed Sheikh
jae.kwon
Are you able to:
1. data shortcut in network #2 into the drawing that has network #1
2. promote network #2
3. merge network #2 into #1 using the merge network command?
Joe-Bouza
I cocur with @jae.kwon  if you do not have the data shortcuts insert ther files into on and merge
Joe Bouza
Jawed-Sheikh
Got it friend. Thank you so much
Regards
M-Jawed Sheikh
