How to combine two curves into one compound curve?
08:17 PM
Hi all,
I am relatively new to using Civil 3D. I am attempting to draw a compound curve. I have created an alignment from objects, with the objects being 3 lines - the tangent of the first curve, the common tangent, and the tangent of the second curve. I then added two curves to this alignment, of 80ft and 150ft respectively. Visually, this curve and alignment is correct. The labeled stationings are correct. However, I am wondering if there is a way to combine these two curves into one continuous curve. Right now, the PT label of the first curve overlaps the PC label of the second curve. Ideally I'd like this to just be one label that says PCC. And also ideally, reducing the two PI's, one PI for each curve, into one shared PI.
Thanks!
