Civil 3D Forum
How to change circular Alignment start point
29 REPLIES 29
Message 1 of 30
Beka_Tchigladze
2625 Views, 29 Replies
Hello
I want to change start point of circular alignment which I create from alignment creation tool it always creates circular alignment from one point and does not gives me opportunity to assign start point.
here is a screen shot it always make start point on point 1 I want to start circular alignment on point 2 how to change starting point?
Beka Tchighladze
Road/Highway Technical Designer
AEC Collection/C3D 2022
WIN 11 64 PRO
Predator Triton 300SE, Intel Core i7 11370H, 24 GB
NVIDIA RTX 3060, 6 GB
YouTube--->Linkedin
29 REPLIES 29
Message 21 of 30
in reply to: Beka_Tchigladze
Joe is a CAD Magician 😀
Message 22 of 30
Joe-Bouza
Nothing up my sleeve...  lol
Joe Bouza
Message 23 of 30
Beka_Tchigladze
in reply to: Joe-Bouza
I saw screen cast, I read your steps several time I do the same but at the end my Alignment disappears 😕
I become crazy
Beka Tchighladze
WIN 11 64 PRO
YouTube--->Linkedin
Message 24 of 30
Joe-Bouza
I understand your frustration.
did you try another file? can you post your file
Joe Bouza
Message 25 of 30
Beka_Tchigladze
please see the attachement
Beka Tchighladze
WIN 11 64 PRO
YouTube--->Linkedin
Message 26 of 30
Joe-Bouza
This will only frustrate you more. I works fine on my computer. I tried to break it but the alignment rotates move etc with no problem. I wonder it it is a graphic setting  on you machine.
Joe Bouza
Message 27 of 30
Beka_Tchigladze
you are really kidding how can I believe it what can I do it is not a graphic problem I have a good computer and driver
Beka Tchighladze
WIN 11 64 PRO
YouTube--->Linkedin
Message 28 of 30
Do AUDIT after rotating the circle. You'll see the alignment again. But the start point will be on its original point. Only labels will move. Rotatinng don’t work for me either. I end up modeling my roundabout in different way.
Message 29 of 30
me too but I need a decision for this method
Beka Tchighladze
WIN 11 64 PRO
YouTube--->Linkedin
Message 30 of 30
@Beka_Tchigladze  I do not know why rotating the alignment is not working for you. It works fine for me. Did you try my other suggestion in comment 14. Using a 2D circle as a template and creating a 3 point fixed curve alignment? You can then independently move both the start and end points to wherever you want them to be. Just leave a gap of 50mm or something between start an end points. You can put the 2D circle on a construction lines layer that you can set to not print and freeze if necessary.
Peter
Rail Community
