Hello everybody,
I am working as a junior CAD technician under the direction of a civil engineer who focuses on drainage projects. I would like to know how best to approach the structuring of files and data in a project where we are creating plan and profile drawings for 6 kilometers of drainage ditch.
Given the size of the drain, I am expecting a total of 15 plots to be made (11 sheets showing profiles, 3 different plan views showing the drainage system, and a location map). Typically, our projects have everything in one file (alignment, profile, topo, surface and layouts), but my boss has instructed me to have all layouts to be plotted in a different file, and xref the model containing the alignments, profiles, linework and profile views.
I've rarely worked with xrefs and data references, so my interpretation so far has been to create the model file with all the profile views, labels, and line work, and xref this into a layout file. In the layout file, I then turn on and off layers to suit the particular plot I'm making. This first attempt is still causing lag in the file with my layouts.
Upon reading previous posts, I think there is support in data referencing the profiles and alignment from the model file, and only creating the profile views in the reference file where I will create my layouts. I suspect the files I will have are:
1 Master model (contains alignment and profiles, topo, surfaces and linework)
2. Sheet with layout tabs for profile views (how many is too much per dwg file?)
3. Sheet with plan views and location plan
What would you recommend is the optimal way to organize the files and layouts to preserve performance?
Ultimately, I want to get the organization of these files right from the start so ACAD doesn't lock up on us and so I don't paint myself into a corner and have to rework everything to make it usable again.
Thanks in advance for your kind assistance.
Paul
