How to automatically calculate area of multiple closed polylines?
knuwan
Message 1 of 49
knuwan
I have this hundreds of closed polylines in different layers.Now I want to calculate the total area for each object/layer type.I would be nice if I have a dynamic table containing the data.
* I dont want to use "Area" cmd and select each PL
*I dont want to create parcels.
Any suggestions?
Thanks.
Accepted solutions (3)
Replies (48)
Message 41 of 49
jae.kwon
Fantastic! Glad it worked for you.
I don't know of any sites that gathered all the Dynamo scripts that are floating out there, but Dynamo for C3D forums is a good place to check https://forum.dynamobim.com/c/civil3d/17
Message 42 of 49
DentonYoder
FYI Civil 3D has map 3D inside it...
Message 43 of 49
ChicagoLooper
Wow! Thanks for the FYI. I'm sure other forum users didn't  know either.
Doh? 😊
Chicagolooper
Message 44 of 49
DentonYoder
I typically turn on menubar so I can see the old menus and then "menuload"  "mapclassic"... to add the map pull-down menu.  Use it a lot!
Message 45 of 49
I have been trying to follow your example. In step 3 after  you start Dynamo you say open the folder where you saved PolylineAreas.dyn . I dont have this file and it wasn't in the download with the file PolylineAreas.dwg.  Where do I get the file PolylineAreas.dyn.
Message 46 of 49
jae.kwon
I think the DYN file is still there on message 17 of this thread
Message 47 of 49
eandersonJQW5V
I am trying to use this to get the area of 50+ closed polylines in my drawing but the Dynamo Player window is blank when I try to path to the drawing. Any ideas?
Message 48 of 49
jdparraMZ2VQ
👍Very interesting solution. Can you explain a bit about the bounding box process you incorporated in your graph?
Message 49 of 49
murugan_pg
Hi
How to use your application? please help me.
