Civil 3D Forum
How to automatic rotate label in section data??
1 REPLY 1
taophatxit
421 Views, 1 Reply
Hello guys!
I am working with bands of profile view and have an issue need your help!
When i use band type with sectional data "Distance from Previous Sample Line", Some distance is not enough space to show the text data in the horizontal direction (you can see in attach file)!
I want the text rotete to vertical direction (at special distance when text hasn't enough space to show in horizontal)
Do you have some solution to me?
Thanks guys!
1 REPLY 1
erdemcelenk
in reply to: taophatxit
Select the related label group, click right, select Edit Band Style. Then click on Compose Label (the one on the right side) In Layout tab, change the Rotation Angle to 90 degrees.
You must do this at each place though (like at major increment , at centerline,at sample line vertices etc. ), depending on the way you 've created the label set.
Erdem Çelenk
Civil Engineer,MSc.
Rail Community
