hello
i am trying to create the river surface
and i want to add words on the surface
how can i do?
thank you
hello
how can i do?
thank you
Check whether this helps you.
What specifc words are you looking for?
Joe Bouza
Joe Bouza
Are you trying to label something like spot elevations of Surface name of do you want the River Name to appear projected on the Surface. If it's text projected on the Surface. You'll have to create a Raster containing the text and Drape it on the Surface.
Allen Jessup
CAD Manager - Designer
Allen Jessup
Sounds Psychodelic
Joe Bouza
Sounds Psychodelic
Joe Bouza
Use the Express Tool Explode Text it will reduce the text to plines. Convert the plines to featurelines and assign elevations from the surface. Raise the feature lines 0.1 units to they always appear on top of the surface. Add these to the surface as breaklines, make a new surface with them or just let them display as is per your wants/needs.
John Mayo
John Mayo
Hello @Anonymous ,
Just checking to see if your problem has been solved. Have you tried the suggestions from our experts above and did any of them work? If yes, please click on the "Accept as Solution" button in their reply so this helps other users in the community find the solution too.
And thank you everyone for helping out!
Hello @Anonymous ,
thank you so much for the hint
that way is only for plan view
i want to add the words to the surface and so i added the height label on the surface
and i edited the height label to words
so there comes words which can be seen not only for 2D view but also for 3D view (along the surface height)
that hint helped me so much
thank you so much
thank you so much
already solved
thank you so much 😀
already solved
thank you so much 😀
thank you so much
but i have no tif data
i will try like this when i have tif data
thank you so much
thank you so much
thank you so much
Awesome! Glad to hear problem solved and thanks for confirming! 😃
If you have typical words to add to “height” labels you can create predifned styles that will contain the words and height
Joe Bouza
Joe Bouza
