Announcements
Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
How to add text in Layout mode in Sabassembly Composer?
 I have crerated some assembly using Composer, when i change the slope  0:1, (it means vertical) the proyection of line goes to the cero in Y axis. So in order to avoid this extension line, i have included  the expression: SA.isLayout in a decision.
But, i would like to include somo text in this mode, in order to make better the presentation of the subassembly when i import in Civil 3D.
I know that it is possible, because we have this option in C3DStockSubAssemblies, like this:
Using SA.isLayout in a decision:
Somebody can help?
Thanks in advance.
KMercier_C3D
Sadly, I do not think the current version of SAC allows users to put informative text for layout in Civil 3D.
Kati Mercier, P.E. | LinkedIn | AutoCAD Civil 3D Certified Professional
Pronouns: She/Her
Co-author of "Mastering AutoCAD Civil 3D 2013"
AU2019 Speaker::: CES321590: Analyze and Revise Existing Subassembly Composer PKT Files for AutoCAD Civil 3D
AU2017 Speaker::: CI125544: Analyze and Devise in Subassembly Composer
AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCAD® Civil 3D®
Buzz0m
Hi Kati!
do you know if this still is the case with SAC2016 (ie. adding informative text for layout mode)? This would greatly improve the workflow in the company I work for...
- F
KMercier_C3D
Still no such luck.
Pronouns: She/Her
