How to add Mtext content as a Property in Polylines
Matheus-Lima
Matheus-Lima
Hello, everybody! I have a question here.
I have a drawing with LOTs of closed polylines, each one with a corresponding name in a mtext. Is there a way to automatically get the name and add it as a property in each polyline? All mtexts are WITHIN the corresponding polyline.
I'm thinking to give it a try to Dynamo creating a property set but maybe someone here knows a way to do it in Civil 3D / Map 3D more easily.
Thanks!
[PT-BR] Se essa postagem foi útil para você, clique em Curtir! Se a resposta resolveu o seu problema, clique em Aceitar Solução.
[EN-US] If it was helpful to you, click on Like! If the answer solved your problem, click on Accept Solution.
Matheus Lima
Civil Engineer | BIM for Infrastructure Enthusiast | BIM Manager | Instagram @bim_infra | LinkedIn
Pointdump
Hi Matheus,
As long as the text is within the closed polylines, you can use >>>Generate Links<<<.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Matheus-Lima
Thanks, Dave! Generate Links did the job perfectly!
Matheus Lima
KirkWM
Thanks for sharing that one, nice little gem.
brian.strandberg
Unless you need it as property set data, I would create parcels from objects.  You get the ability to get the area, label the length of each parcel segment, export data tables, and still use property sets.
Check out my Civil 3d blog at: http://c3dk.com/
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Fast Track your site grading with the new Corridor Workflow: https://youtu.be/Gg7u9-LgIL0
