How to add a new attribute to multiple blocks
hamza_acharoui
hamza_acharoui
Hello there i have a plan drawing and the rooms are represented in different blocks. My aim is to add a new attribute to some selected blocks to give them some sort of classification. How am i able do this as efficiently as i can. Also the simpler the better.
Thank you.
MMcCall402
Adding an attribute needs to be be done one block definition at a time.  Run ATTSYNC after the attribute addition for the currently inserted blocks to update their attribute(s) with the revised block definition. All insertions of that block will then have that attribute available.
Mark Mccall
CAD Mangler
VHB - Engineering, Inc.
