How should I bring someone else's drawing into my CAD template: XREF, Insert, Copy???
We get drawings from other engineering firms. I bring them into my CAD template drawing so I have all my settings.
I don't know the best way to bring their drawings into mine. Because we are finding errors when bringing in different ways. I am learning a little about the UNITS: "FEET" vs "US SURVEY FEET".
I have tried bringing in a Proposed Site Plan CAD drawing different ways and gotten different results!!! One drawing was UNITLESS. When I did an INSERT it came in in a totally different location and a totally different scale likes scaled 24x from 0,0,0). When I copied everything from 0,0,0 and pasted to 0,0,0 it came in what seemed to be OK in the "right" location.
Then I brought in an Existing Conditions Survey CAD. I did an XREF and it came in 1.727' away from the "right" location. But if I copied and pasted 0,0,0 it came in in the "right" location. I found out that drawing was in "FEET" instead of being in "US SURVEY FEET". When I changed it to "US SURVEY FEET" and saved and then XREF'd it in it came in the "right" location. I was saying "right" because I wasn't sure which location was correct. Verifying point coordinates I found out the "right" was the correct location.
I like using XREF because I can turn it all on and all off in one shot (one layer). I don't like the copy/paste because if anything is Frozen or Off it will NOT copy, and sometimes I don't want to turn on EVERYTHING from another company because I don't know what all their excess layers are. That is why I like INSERT because it inserts everything whether off or frozen. But sometimes that doesn't work (as above).
Also is there a way to get an architectural drawing to insert into a CAD drawing at the proper scale? It "usually" comes in at 12x the scale and I just scale it down. But NOT ALL THE TIME (sometimes it is 1:1). Is there any way for CAD to determine if a drawing's scale is different and bring it in in the correct scale?
