How do you get two horizontal pipe runs to connect to each other?
hchanZFNCT
hchanZFNCT
Joao-Rafael
if I understand your need well, you can use the Grips at the end of each pipe to make the connection.
remembering the functions of pipe grips in pressurized networks:
1- Square: Move
2- Triangle: Length
3- Diamond: Deflection
4- + : Continue Plot
in this case you must use the Grip Triangulo to make the connection between the ends of the pipes.
remembering to observe the allowed deflections
At.t
João Rafael A. Dias
[pt] Esse post foi de ajuda para você? Mostre seu Apoio dando uma curtida! Sua pergunta obteve uma resposta que resolveu a duvida? Então clique no botão 'Aceitar Solução '
[en] Did this post help you? Show your support by liking it! Did your question receive an answer that solved your doubts? Then click on the "Accept Solution" button.
[es] ¿Te ayudó esta publicación? Demuestra tu apoyo dándole un me gust. ¿Tu pregunta recibió una respuesta que resolvió tus dudas? Entonces haz clic en el botón "Aceptar solución"
Siga-me // Folow me LinkedIN
ledat555666
Community Visitor
Community Visitor
Thank you for sharing your knowledge,
hchanZFNCT
I tried using the triangle and the compass to connect the pipe but it won't connect. I get the symbol to make a connection but it remains open when I do. If I run a design check it says its still open.
Cadguru42
It looks like there are two pipes on top of each other from your screenshot. When you do the grip edit to connect it might be trying to connect the pipes to each other instead of the fitting.
C3D 2022-2025
Windows 11
32GB RAM
hchanZFNCT
The solution is to disconnect the parts from the network then click and drag the pipes together.
