How do you generate a bottom TIN surface from three-dimensional modeled object?
I received a dxf file of a modeled contamination plume containing 3d face objects (See 1st image below). This "plume" was modeled using C Tech's Earth Volumetric Studio (EVS). I now need to create a TIN surface of the bottom of the plume. I've tried doing by "Adding Object Data To A Surface", but because the 3d face objects are essentially a three-dimensional object, the TIN surface created is not accurate (see 2nd image below).
Does anyone know how to generate a bottom surface from three-dimensional object?
I've attached the DWG file for reference.
Image 1 = modeled contamination plume
Image 2 = TIN Surface Generated Using 3D Faces
