Announcements
How do I reorder fields in a object data table (ADEDEFDATA)?
lglowackiGCI
lglowackiGCI
I've added a new field using ADEDEFDATA which places at the end of the list. How do I move the new field near the top of the list? Removing and re-setting fields is not an option. Mayby lisp can do that? e.g. Rename_Field.lsp can rename fields very well @АлексЮстасу im using ODEDIT
АлексЮстасу
Option with Lisp from @CADaSchtroumpf:
1. Export OD Content in CSV - All_OD2CSV.lsp
2. Reorder columns (fields) in CSV using the table editor. For example, Excel or the like.
3. Import CSV into OD - CSV2OD.lsp
... By the way, can rename the OD fields in the same way.
... And, by the way, OD is a Map 3D tool, and it is better to discuss them at the Map 3D forum.
-- Alexander, private person, pacifist, english only with translator 🙂 --
Object-modeling _ odclass-odedit.com _ Help
lglowackiGCI
I just tested it, everything works like you said you can rename fields and even add them. GREAT!
