How do I remove architectural MEP modules from drawing?
bcsurvey
bcsurvey
So apparently I was ignorant of how horrendously slow a C3D dwg becomes when an architect's block is inserted.  I've probably lost at least an hour a day for the last 2 weeks before being informed that it is most likely due to the MEP items bogging things down.  I looked at the command line history once the dwg had fully opened and sure enough, there are 3 or 4 MEP base modules shown as having loaded.
I'm told the only way to remedy the situation is to cut and paste or re-reference into a new blank drawing.  Is this true?  Before I start down this road, I'd like to know if there's a way to just purge these items out somehow.
Thanks!
Civil 3D 2025 (2.5)
Windows 11 Enterprise (24H2)
(i7-13850HX @ 2.10 GHz)
64GB RAM
NVIDIA RTX 4000
sboon
Have you tried purging Regapps?
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
bcsurvey
Searching in C3D Help for "Regapps", I was first led to an Autodesk app that cleans dwg files. Well that didn't seem to work - I still saw the 4 MEP items loading when opening subject dwg file. Then I discovered the -purge command which I believe is what you were referring to. I'd always just gone through the "purge" dialogue which doesn't include the regapp category Anyway, after messing with that a few times, it occurred to me I hadn't exploded all client-rooted blocks from dwg. It was well beyond quitting time when I'd gotten the blocks blown up and purged. I had just started into Design Center when I had to leave (was running extremely slow for only 34 blocks in the dwg). I'll pick back up tomorrow and report back.
Sent via the Samsung Galaxy Note5, an AT&T 4G LTE smartphone
Civil 3D 2025 (2.5)
64GB RAM
NVIDIA RTX 4000
bcsurvey
After a back and forth of exploding blocks and purging various types of items, I think I'm good.  I believe it was a combination of using the -purge command with R for Regapps, and using this tool:
https://knowledge.autodesk.com/support/autocad-map-3d/downloads/caas/downloads/content/regapp-id-cle...
Says 2015 but I read it also works fine with 2016.  It seemed that I had to get rid of ALL foreign blocks, layers, and linetypes before I stopped seeing the MEP items loading.  What's weird is that I saw them loading when opening C3D a few times, though I think it has stopped.
Civil 3D 2025 (2.5)
64GB RAM
NVIDIA RTX 4000
