Announcements
Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Civil 3D Forum
How do I georeference an aerial into Civil 3D?
7 REPLIES 7
Message 1 of 8
2052 Views, 7 Replies
How do I go about inserting an aerial image into Civil 3D amd make it georeferenced into the correct location?  Which aerial should I use?  Where should I go to get the aerial and how do I insert it?  I hate that Autodesk makes every little task so extremely complicated.
7 REPLIES 7
Message 2 of 8
wfberry
If you have your drawing set up properly with your coordinate system and have a boundary survey (or any objects in the plan.) set in the drawing, it is just a matter of a few seconds after selecting the GEOLOCATION menu the map will pop in.  Select the Map Aerial, it is a Bing Map.
Bill
Message 3 of 8
in reply to: wfberry
Thanks.  I have been using regular Autocad for over 20 years but I complete suck with Civil 3D.
Message 4 of 8
rkmcswain
@Anonymous  - it's the same command in AutoCAD, although the process is slightly easier in C3D since all you really need to do is set your coordinate system.
FYI: The Bing imagery is older and generally poorer in quailty than say Google (for example). There are commercial 3rd party apps that can import Google imagery, and imagery from other sources.
R.K. McSwain     | CADpanacea | on twitter
Message 5 of 8
in reply to: rkmcswain
Thanks, but that is way over my head.  I have no idea how to set a coordinate system.
Message 6 of 8
rkmcswain
@Anonymous  - it's easy in Civil 3D.
Go to the C3D Toolspace > Settings > Select your drawing, right-click, select Edit Drawing Settings > Go to the Units and Zone tab > Make your selection. Done.
For a detailed explanation:
Message 7 of 8
whatever you do, don't ask how to use C3D in architectural units.
Message 8 of 8
I hate architectural units.
Rail Community
