Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
How do I create half drainage pipes to collect water and connect them to the drainage system in Civil 3D?
Telles0808
Telles0808
How do I create half drainage pipes to collect water and connect them to the drainage system in Civil 3D? Should I use the same assembly as a street or is there a more appropriate system for drainage?
matt_anderson_pe
Open channels and Civil 3D gravity networks do not compatible.
A corridor surface for channel can create a surface, which can drive elevations of surface elements of a pipe network.
Matthew Anderson, PE
Telles0808
I was curious about exactly that—using a final surface and allowing water to flow through the curbs. Thank you for clarifying. Currently, I'm in the process of mastering the intricacies of pipe networking.
