How do I construct the table row and the staggered ticks as below?
soonhui
soonhui
Here's the drawing.
So how do I construct the table row  ( such as "Elevation", "Offset") for my section view ( as shown above)?
And how do I construct the staggered ticks that have the levels attached also?
Ngu Soon Hui
I'm the Benevolent Dictator for Life for MiTS Software.
Read more at here
teerawat.pSCHYQ
Hi @soonhui  that table is Data Band, you need to have a look on the section view property, when you understand this data band then you can do staggered label on each data band, it similar what I reply in that you asking about break labeling would like to show on the bottom.
soonhui
Thanks @teerawat.pSCHYQ , I manage to figure out how to configure the table row label like how to change the string for "Elevation" ( ie: I change it to 长度 in Chinese if I want to), as shown below:
But I don't know how to ensure that it is really reading the numerical value of the Elevation and labelling at that specific offset, which depends on the EG surface ( eg: 64.615m).
I do find something like Valid property fields for use with AeccBandLabelStyle text components, but unsure how to apply it ( or whether it's relevant) because I don't see that my drawing uses any of these.
Ngu Soon Hui
Read more at here
teerawat.pSCHYQ
the numbering value is depend what properties that you select in the content such as section 1 elevation, offset, section 1 elevation minus section 2 elevation ....etc...  after you select correct properties then you need to make sure that you press the arrow button into your content
soonhui
@teerawat.pSCHYQ , exactly where do I select in (what) content? The screenshot below doesn't seem to suggest that I can select any of them, be it section 1 elevation, offset, section 1 elevation...
Ngu Soon Hui
Read more at here
