Announcements
Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
how do i calculate where these 2 surfaces intersect?
MKH-VB
MKH-VB
I am working out a grading plan for my engineer. On my attached image, I have existing ground (dashed), proposed ground (blue) and then there is a top of rock surface (continuous red).  I am looking to draw a line in the plan of the point I have marked in yellow. The intersecting point of the rock and proposed surfaces.  Anybody have any suggestions on how i can do this? Thankssurface-int.PNG
mkh
Jeff_M
MinimumDistBetweenSurfaces, it's on the Analyze Tab, Ground Data, pull down....
Jeff_M, also a frequent Swamper
MKH-VB
thanks very much. That worked perfectly.  As I thought about it, I did a volume surface between the proposed and the top of rock.  Came up with a "zero" contour, that matched the way you instructed me. I appreciate it very much.
mkh
neilyj666
This is what the minimum dist between surfaces finds without you having to go through the whole create vol surfsce and extracting zero contour.
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
