Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
How can I remove the top Major Axis Label?
khughesRWC
khughesRWC
I would like to remove the top Major Axis Label, but keep the rest of my labels. I know I can remove the bottom "tick and start elevation" on the Vertical Axes tab of my profile view style, but can I do the same for the top elevation?
jroot
I haven't tried this but could you set your max elev to 14.9999 so it won't label the "15", then draw a line on the top of the profile view to complete the border?
tcorey
Profile View Properties.
Elevations tab. Set Elevation Range to User Specified Height. Set the max height to 0.01 below the elevation of that major grid.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
khughesRWC
I guess this can work. I was just hoping I could modify the style to automate the steps, rather than going in and changing the profile view properties on each sheet 😑
tcorey
@khughesRWC ,
Instead of changing the Profile View Properties, you could place a wipeout over the label. That would be quicker, if not ideal. There is nothing, that I know of, that would let you accomplish this through modifying the profile view style.
Tim Corey
Redding, CA
tcorey
@jroot Great minds think alike.
Tim Corey
Redding, CA
