How can I dynamically connect these Alignments
This widget could not be displayed.
Attached is a snippet showing road centerline Alignments (A B & C). I want to dynamically link these alignments together vertically so their profiles match. The white arrows or blue hatched areas are the intersections I want to connect. The second attachment shows Alignment A & B's profiles. The magenta lines and white arrows are where I want to lock my profiles together. Is it possible to link Alignments/profiles together at their intersection points?
Any information helps,
Thanks!
Replies (7)
guanleng.sim
Autodesk Support
Autodesk Support
Hi @Anonymous You can refer to the Civil 3D help in the following page. It might help.
To Create Connected Alignments
Guan Leng .Sim
Specialist Technical Support Civil 3D
fcernst
This isn't correct information from Autodesk..
He needs to create Intersections in this example.
Fred Ernst, PE
C3D 2025
Ernst Engineering
www.ernstengineering.com
jmayo-EE
Fred is correct the intersection will lock profiles. You can use this even without creating the corridor if you don't need a full model.
John Mayo
Yes! I started playing with the intersection command and it seems to lock profile elevations together. However, if two alignments intersect twice I cannot create another intersection. Referring back to the snippet... Alignment A & B cross twice. I guess I could split Alignment B into two different Alignments? I would rather not if there is different solution.
Thanks for the reply
Also this is a mass grading for a 200 lot subdivision.. so I have to take this into great detail using Corridors, Subassemblies, and intersections 🤒. I am trying to set myself up proper now so I don't run into problems later.
samir_rezk
Hi @Anonymous
I agree with you, I wouldn't split the Alignments; but I also wanted to add a screen capture of the different types of Profile Locking you can do!
Hope this helps,
Samir Rezk
Technical Support Specialist
neilyj666
I think this is the default behaviour and you will need to split the alignment
AEC Collection 2025 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
