Hi everyone!
I would like to know, if it is possible, to show some labels in viewport but, the same texts, doesn't appear in another viewport? (working in paper space).
[Sorry for any grammatical mistakes]
in layer properties you have option to freeze layer in viewport, so you need just freeze layer on which ever are your labels for that viewport
freeze layers
with labels
Hello @Igorfinriv ,
Just checking to see if your problem has been solved. Did the response from @Anonymous help answer your question? If yes, please click on the "Accept as Solution" button in his reply so this helps other users in the community find the solution too. Thanks!
