Hello!
I'm working on a document that needs parameters applied to "Pipes", "Structures", "Thin Surfaces", etc. I created a Property Set Definition (PSD) with all the necessary parameters.
For some unknown reason, the PSDs duplicated excessively, resulting in over 6,000 duplicated PSDs in our drawings.
I found an Autodesk Support Issue (https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-delete-dupl...) with a LISP routine that helped us merge the PSDs, but it was a time-consuming process.
After cleaning up the PSDs, I saved the document, made a backup, and continued working. I deleted some broken Surface references and then purged the drawing.
Suddenly, new PSDs appeared, as shown in the picture below.
Duplicated PSDs
The PSDs "SNR_IE (2)", "SNR_IE (3)", "SNR_IE (4)", and "SNR_IE (5)" are duplicates of the original "SNR_IE".
I didn't use any commands to duplicate the original PSD. My question is, what could be causing the PSD to duplicate?
