Civil 3D Forum
HELP.... Add Lane Widening problem
2 REPLIES 2
1053 Views, 2 Replies
Im using civil 3d UKIE 64bit, having a serious problem with adding a lane widening to an offset alignment. It is a straight alignment approx 200m length, but when i enter the paremeters that is asked, at the end it says no solution!!
Tried the things associated with this help topic!
Can one help please??
2 REPLIES 2
mathewkol
If you could update your quesiton to give more specific details.  Widening works fine here.  It's impossible to tell for sure if we don't know your exact scenario.  Attach a DWG with instructions on how/what to widen.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
On the mainline corridor, if i create a centreline alignment, then create an off-set alignment to that at 3.000m to the left, but on the right i wish to create a 2.5m right turning lane at the junction, and a 3.0m lane also, so three lanes in total on the cariageway, from this i will then use the create an intersection command?
The widening i wish to create has a station starting point of CH10m, End station of CH235 off the centreline alignment, with a taper of 75m on each end.
Hope this is enough info?
Cheers
Rail Community
