Help - acad proxy entities - data extract
Message 1 of 10
Hello!
So I am using autocad Civil 3D 2012 and I have a dwg that has some spot elevations that are stuck as proxy entities.
My end goal is to create an ascii file including the x,y,z coordinates of these spots.
I realize the only easy way to do this is to have the author of the dwg save it back to 2012, but I can't do this.
I have tried listing the spots in TrueVIew and I can see that they are cogo points and it shows all the information I need in the command prompt but I need to export it somehow.
If anyone has experience with this please let me know!
Thank you in advance!
Replies (9)
Message 2 of 10
tmachado
Hi @Anonymous, I downloaded your drawing but it is not information on it...
Hope this will help!
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the LIKES button
Tatiana Machado
BIM Manager/ Autodesk Certified Instructor
Blog | Twitter | LinkedIn
InfraWorks Ambassador
Message 3 of 10
*EDIT *
This is the correct attachment
Message 4 of 10
Hi!
Thank you for replying, I have attached the correct dwg now.
Message 5 of 10
tmachado
Here you go @Anonymous, the attached file is txt file format PNEZD comma delimited
Tatiana Machado
Message 6 of 10
That is perfect! Thank you
How in the world did you do that?
Message 7 of 10
tmachado
I am using C3D 2018 so I can open anything older than that.
1. Rigthclick on points from your Prospector tree and select export points
2017-06-08 14_48_51-Autodesk AutoCAD Civil 3D 2018 - [Asphalt Path - proxy entites(1).dwg].png
2. Then choose a file format from the pulldown list, give it a name, a location and select a file type to export
2017-06-08 14_49_40-Autodesk AutoCAD Civil 3D 2018 - [Asphalt Path - proxy entites(1).dwg].png
It is my pleasure to help 😉
Tatiana Machado
Message 8 of 10
Oh I see. This is great for now, but I still need to be able to do it myself in the 2012 version.
Thank you for you help!
Message 9 of 10
tmachado
You can't do a Data Extraction from Proxy objects to get x,y,z location
1. So the next time ask whoever sent you the file to do a _AecExportToAutoCAD2010
2. That will show all the COGO points as block of reference with x,y,z
3. Create a surface from them (Surface -> Definition -> add drawing objects -> blocks)
4. Change the surface style to show the surface points
5. Use this command to extract the points from the surface _AeccSurfaceExtractObjects
This will create regular ACAD points that you can do a DATAEXTRACTION or you can create COGO from.
Is a long workflow but that is what I could come out with for now...
Tatiana Machado
Message 10 of 10
Okay thank you!
You have been a great help!
