To further illustrate why you should download contour shapefile and not elevation data, see image-1.
1-Get shapefile from Topo Data Map and Topo Stylesheet.
The elevation data is the green raster, and the contours, which are yellow, are vectors and are limited to the extent of a 7.5 minute topo quadrangle, in your case Kempner Quad. If you download the raster, you're getting more data, way more data, than you need, image-2. You can make contours from the raster but why do that when you can get download the contour shapefile itself?
2-Raster vs. Contour Shapefile.
The example below illustrates both raster and the vector data (contours) overlaid one another. You can clearly see the contours are more than sufficient in providing the necessary coverage for your 300-acre site. The aerial photo with the blue parcel boundaries was downloaded from Lampasas County Central Appraisal District (lampasascad.org), View County Maps. The RED geomarker, labeled The Site, is in the middle of your project and was located using the coordinates you provided in post #12. If you look closely at image-2 above, you can see the RED geomarker amongst the yellow contours.
3-The Red geomarker is in the middle of your 300-acre parcel. Yellow contours provide more than enough coverage.
Chicagolooper
