Civil 3D Forum
Hatches w/Same Properties Plotting Different in Same Viewport
5 REPLIES 5
KDeChambeauM237A
270 Views, 5 Replies
I have some shoulder hatches that have the exact same properties in my basemap but when xref'd into a drawing, they plot very differently in the same viewport. I will attach a screen grab showing the difference.
Has anyone seen this issue before? Its happening in 2022 and 2024 versions of Civil3D.
Solution: I ended up changing the scale of both hatches in the original file until I found a scale that plots the same in the viewport.
Tags (1)
Labels (1)
5 REPLIES 5
Ok, that picture really tells us nothing.
It does look like the scale is larger on the upper hatch which will produce visible differences.
WBLOCK out the hatches into a new drawing and post it here, or post pictures of the hatch properties and the difference between display and plotting.
Try FLATTEN on the hatches
Joe Bouza
Use the Match command to match the good one to the bad one.
Mark Mccall
CAD Mangler
Hammer Land Engineering
Linkedin
I already have done that. The hatched have all the same properties.
Share the drawing so we can take a look at it instead of just guessing at what the problem may be.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Rail Community
