I'm working on a drawing where I am essentially creating a valley fill. I used 'grade to surface' to create the grading surface. However, when it creates the surface, it daylights correctly on one side of the valley, but it stops short of daylighting on the other side. I have attached a pdf that marks up the issue visually and also included the drawing file. Any ideas why it's not daylighting on that one side of the surface?
Link copied
