Grading Tools for Grading Feature Lines with Large Slopes
Hello Everyone,
In the attached drawing, you will find a surface which I have creating using grading objects. One issue I am having is on the southeast corner of the surface. It appears that in that corner there is a slope of about 45%. This is an issue since the maximum allowable slope for this surface is 33.3% (or 3H:1V). I am wondering, using this surface, what is the easiest way to regrade this area so that the final finished surface is 3:1. The original grading object in this area was created using one feature line which had a grade break where you are seeing this change in slope. I believe the resultant slope vector using a 3:1 grading combine with the vertical grade break caused a larger than 3:1 slope on the final surface.
All help is appreciated. Thanks,
