Is there a setting for the tessellation (triangles) interval on a surface made from grading tools to be changed?
I am grading from a featureline and the resultant surface is making triangles at 10' along the featureline.
I am trying to reduce the data generated to see if the grading will be more stable.
I know, I usually use corridors but this was started by someone else.๐
JL
Civil 3D 2020
Of course I just found it right after my post.
Grading Group Properties.
Automatic surface Creation
Tessellation Spacing
Thank you self.
Happens to me all the time
Joe Bouza
Tell us where so someone with a similar problem can get help.
then you can select your own solution accepted or I can do it for you
A screen grab would be excellent
Joe Bouza
