I am trying to use a corridor to grade this bulbous little half cul-de-sac eyebrow type roadway. I am having trouble with the return of the bulb as it runs back North, it is too perpendicular to the alignment/corridor. I have tried changing the 2-dimensional shape of the bulb slightly but I can't change it enough to help the issue I'm having. I have also changed the frequency of the offset target curve and that helped smooth it out but it is still overlapping some in that area, not really bow-tie though.
Looking for the best course of action to fix it, I am almost debating just splitting the corridor regions over that span and connect the two regions with Feature Lines along that return. Otherwise some sort of offset alignment or something should be able to help I think? Any help would be appreciated! Thanks.
