Civil 3D Forum
Grade feature lines to one another
34 REPLIES 34
Message 1 of 35
1299 Views, 34 Replies
I have two feature lines I want to grade towards each other at different grades until they meet. Is this possible, and if so, how? Thanks.
34 REPLIES 34
Message 2 of 35
Joe-Bouza
You need to give a little more destail. Are you wanting to set the elvation of one from the other? See the elevation editing tool on the ribbon
Joe Bouza
Message 3 of 35
tcorey
Yes, this is possible.
Be sure both gradings are in the same grading group. If so, the slopes will intersect automatically if they overlap.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 4 of 35
If the two feature lines are closed try In Fill Grading
Message 5 of 35
in reply to: tcorey
Which grading criteria would I use to do that?
Message 6 of 35
Joe-Bouza
That would be the criterior of you choosing; if they intersect they will do as Tim says
Joe Bouza
Message 7 of 35
Okay, I've attached a graphic. I have a CL of a channel and the edges of the lake it runs through. I want to grade out from the channel at 10:1 and in from the edges at 4:1 to a point where they would meet. I'm not having any luck w/ anything I've tried. I welcome all suggestions. Thanks.
Message 8 of 35
Joe-Bouza
Hello Charles
One thing I would not do is attach a grading to those squiggly outside feature lines.
Are you looking to set the grade of any/all of those feature lines?
Joe Bouza
Message 9 of 35
Joe-Bouza
in reply to: Joe-Bouza
Gradings don't like going around the concave segment. Thats a challenge alright. There is a way just gotta figure out how civil3d want to do it.
Maybe a corridor with some kind of condition daylight to ROW thingy?
Joe Bouza
Message 10 of 35
jmayo-EE
Can you share that simple linework?
John Mayo
Message 11 of 35
in reply to: jmayo-EE
Here's a dwg w/ the feature lines. Thanks,
Message 12 of 35
Joe-Bouza
The north side is only a pline?
Joe Bouza
Message 13 of 35
So it is. I just hadn't converted it yet. I was having issues trying to the Westerly-Southerly side to work and never tried that side.
Message 14 of 35
Joe-Bouza
So I casn assume iut is also 509.8'?
Joe Bouza
Message 15 of 35
yes, the edges are 509.8 and the channel is variable elevations
Message 16 of 35
doni49
I had a very similar situation just a couple months ago.  I used a grading object from the outer boundary and then exploded it to polylines so that I could "clean it up".  Because it's so jagged, the resulting grading object had a LOT of crossing lines which C3D doesn't like.
Here are two threads you might be interested in.
http://forums.autodesk.com/t5/AutoCAD-Civil-3D-General/Surface-to-Exclude-all-above-specific-elevati...
http://forums.autodesk.com/t5/AutoCAD-Civil-3D-General/Two-breaklines-at-same-elevation-Large-Gap-be...
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
Message 17 of 35
in reply to: doni49
Just a thought, it's a bit of a work-around but it might work.
You could have your two feature lines (your banks I believe) and grade it down at 4:1; but you'd have to make it extend relatively far. This will make everything slope down away from the bank, but not necessarily towards the CL (especially the meander at your southern bank).
Then you create a separate grading group (or corridor) that daylights to the first surface.
Make a new surface and paste surface 2 on the Surface 1 and (in my head anyway) it should get what you want
Message 18 of 35
Joe-Bouza
I like tha idea rendarin
I, like you have an issue with the meandering portion.
I closed the TOB artificially, added an infill, then the 10:1 gradings with variable width, thus lettin the TOB be approximate 4:1
Joe Bouza
Message 19 of 35
david.zavislan
Another option is to model each of the slope surfaces separately and then use the Analyze > Ground Data > Minimum Distance Between Surfaces command.  This will generate a 3D polyline where the selected surfaces intersect.  You can then use the 3D Polylines as breakline data in your final surface.
The following images show this done with two different slope surfaces.
Final surface:
David Zavislan, P.E. | Wood Rodgers, Inc.
Message 20 of 35
fcernst
A Corridor implementing the  LinkSlopesBetweenPoints subassembly.
Fred Ernst, PE
C3D 2025
Ernst Engineering
www.ernstengineering.com
Rail Community
