I'm having a problem while using the Generic Link Slope to surface subassembly.
getting a Cut instead of Fill link.
any Suggestion ?
Solved by yaseenw.1. Go to Solution.
Hi @yaseenw.1 ,
In the first place I would suggest to check if the target surface allows to generate a link properly:
Are those conditions met?
Also I encourage you to review the help file for this particular subassembly for better understanding the workflow and conditions that apply for use. See below:
you can check the pics I attached in the post, i think i've made all the conditions as they should be.
i've found out how to fix this issue.
the correct way to define this Subassembly is to set it to " Cut Only " or " Fill only " in the subassembly properties. while defining the properties this way the daylights won't get wrong.
