The project I am working on, I need to construct a road between two existing curbs. I have the alignment set with the two offset alignments representing the existing curbs. We are going to use the existing grade, slope, gutter, everything on the road. The concrete will be cut out and then re-poured.
I need for the assembly to go from one curb to the other, and as the existing elevations change I need the road to change as well. the crown of the road is not consistant. I need this so that I can generate section views of the new road.
I have seen this as a possibility:
1. add a generic "linkwidthandslope" from the center line to the back of curb point where
the slope of the link is controlled by the curb profile.
2. add the curb and lane to that, working them back to the centerline.
3. once it is working, turn off the display of the generic link.
4. repeat for the other side.
I understand the concept of what is being said. using the offset alignment and going back to the center to make it work.
however, I am pretty new to civil 3d. I am having a hard time actually perfoming the task. I am not sure of all of the commands or how to target these items in order to actually perform the function.
In a video "advanced features corridors, assemblies, and the use of targets in civil 3d" by CAD-1 on youtube, the exact thing I am trying to do is addressed at 39 minutes into the video. However, he does the commands so quickly I am unable to follow.
If anyone knows of a video or has a more detailed description of how this can be done I would be forever grateful.
Here is the above referenced video:
