Geomap fade
mikespelts
Geomap fade
mikespelts
Is there a way to adjust the way the Geomap imagery displays? I would like to fade it back a bit so it's easier to see my linework in the foreground. Specifically would like a darker gray background in the "Map Road" mode. Maybe a feature to add in future releases.
brian.strandberg
When you add a GEOMAPIMAGE, you get full control over BRIGHTNESS, CONTRAST and FADE.  This also works in map and hybrid views.
Hope this helps.
Check out my Civil 3d blog at: http://c3dk.com/
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Fast Track your site grading with the new Corridor Workflow: https://youtu.be/Gg7u9-LgIL0
mikespelts
Thanks Brian, I knew when I performed a "Capture Area" that I had these capabilities but I did not like how the resolution was then fixed. However in playing with it some more I see that there is some ability to reload and increase the resolution of a captured image. However I cannot get it the image as clear as it is when zooming in before a capture, so I still would like to fade without capturing.
neilyj666
Don't believe it is possible without capturing - It could be that the available imagery is at its highest possible resolution as in my experience not all areas are available at all resolutions
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2025 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
brian.strandberg
I usually see varying differences in resolution of the original aerial image.  Urban areas seem to be better, rural less good.  I have attached  an example.  Both views have the same scale 1"=20', and Hybred map view and same geomap resolution settings.
You can clearly see the difference in resolution between both views.
jflovett
Observer
Observer
Try doing a solid black hatch on a locked layer around your entire work area on the map, then send the hatch to back and adjust the layer's transparency until your satisfied with the darkening of the background image.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
