Geolocation not working
Eric_L_Vallejo
Eric_L_Vallejo
I have a user whos Geolocation function is not working within Civil 3D 2021; trying to overlay an Aerial\Map.  I verified UCS, coordinate system and Zone; all are correct.  I tested the .dwg on multiple machines and it works on all except for this particular user.  Any suggestions? Hotfix I don't know about?
Eric Vallejo
Eric_L_Vallejo
Found the Solution: Turns out the user clicked no when asked to view maps online and saved his preference.  To bring the dialog box back, I went into options to prompt:
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2021/ENU/AutoC...
rl_jackson
@Eric_L_Vallejo I marked you solution as accepted so that others with the problem, might find the solution useful.
Rick Jackson
Survey CAD Technician VI
