GeographicLocation issue inquiry
jeffrey.s.barrero
jeffrey.s.barrero
Good day
I have not been able to use the GeoGraphicLocation mapping services in Civil 3D 2024 and up. and I've attached the two screens that I am getting when trying to use it but unfortunately the IT team where I work have not been able to resolve it.
I am curious if anyone has experience the same thing, and have idntified a workaround or a solution.
Please let me know if there are any questions, or suggestions for me to go about troubleshoot this issue.
Thank you, and I wish you a great day
Jeffrey Barrero
AllenJessup
There may have been an issue at one point. Make sure you have all updates installed. I don't know much else since I don't use Bing or ESRI images.
Allen Jessup
CAD Manager - Designer
Pointdump
Hi Jeffrey,
Don't use Geographic Location. That is meant for Vanilla AutoCAD, and it usually trashes C3D and Map 3D drawings. Use either MAPCSASSIGN/MAPCSLIBRARY or set your coordinate system in Drawing Settings. If you need to search for a particular location, use Zoom >> Center and 'NE or 'LL.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
ChicagoLooper
Hi @jeffrey.s.barrero
First things first......get your Aerial imagery working (e.g. Bing Maps).
Try this:
  1. Open a blank template, the type with one layer named 0 (zero). Don't use your firm's office template.
  2. Command line=>MAPCSASSIGN=>In search box, enter 3857=>Select or highlight the search result=>Click Assign
  3. Go to Geolocation Tab=>Turn on Map with Aerial Imagery (e.g. Bing Hybrid) <<Zoom out to see the map.>>
  4. Geolocation Tab=>Location Panel=>Click Remove Location=>Yes to confirm
  5. Next, use MAPCSASSIGN to establish your desired coordinate system then turn on aerial imagery (e.g. Bing Hybrid).
***Note: Don't use the Geolocation button, that way is tricky.***
<<Don't make the mistaking of thinking the Geolocation button doesn't work. It works, but it's tricky.>>
BTW, if aerial image doesn't appear in step #3, then your AutoCAD program is not able to connect to the internet.
Chicagolooper
