I am trying to format bearings to the nearest second and distanced to 0.01ft. I've tried dimstyle - make the changes as wnated but someow it doesn't work. I get nowhere at all trying to edit label styles.
you are mixing two different work space setting and they, and I say this loosely, have nothing to do with the other. Either way, they can both be set to do what you are seeking.
DIMSTYLE is an AutoCAD environment setting that only affects AutoCAD dimensions
LABEL STYLES are a civil3d setting that only affect civil3d labels
AutoCAD dimension style setting
civil3d label style settings
Joe Bouza
