Announcements
Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Folks who grade for private development: Do you use surface smoothing?
AuditInPaperSpace
AuditInPaperSpace
If you work on commercial, industrial, multifamily, etc. I want to hear your thoughts on surface smoothing. Do you use it? Why or why not? If you do, what do you think of it? Are there any common problems you run into?
Looking forward to hearing from you!
neilyj666
I don't work on any of these projects but do not use surface smoothing as I prefer to add additional breaklines/points etc to create a representative surface. Contour lines are only as good as the underlying DTM and the defined spacing and if smoothed and used by a third party to rebuild a DTM could give erroneous results.
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
