Flatten does not work.
hey guys,
I am in civil3D 2017 and when I want to flatten a topographic survey drawing it give me the below error
bad argument type: lselsetp nil
any better way you know to solve the problem?
pendean
Community Legend
Community Legend
lynn_zhang
Hello @Anonymous ,
Just checking to see if your problem has been solved. Did the response from Dean help answer your question? If yes, please click on the "Accept as Solution" button in his reply so this helps other users in the community find the solution too. Thanks!
Lynn Zhang
rl_jackson
Most likely you'll need to explode all C3D objects to there primitive form  prior to running that command, FLATTEN per-dates C3D, so it most likely doesn't work on certain objects.
Rick Jackson
Survey CAD Technician VI
