Fixing Jagged Edges in Lighting Heatmap Map between 2 Surfaces
- Mute
- Permalink
- Report
Extremely new to Civil3D so please bear with me. I am using a procedure to calculate Volume Cut and Fill Between 2 Surfaces for the purpose of presenting lighting effectiveness on an airfield. So far we have two csv files:
- Ground Level (-104.66995, 39.86337, 0)
- Lumens (-104.66995, 39.86337, 244.22)
The data is presented as Long, Lat, Point Elevation where the point elevation is lumens. The ground level data set is simply the lumen data set in the same positions but with 0 lumens.
So far it appears to be working. The only issue now is fixing the jagged edges. How do I fix the jagged edges?
Video I followed:
https://www.youtube.com/watch?v=3biSwad8hbQ
Questions:
1. Will this procedure work?
2. How do you get rid/correct the jagged edges?
3. Are there better methods of doing this?
