I am creating a couple of notes in “Project A”, that reference other sheet set project names AND descriptions, “Project B” & “Project C”. I can create the notes and it will visually look fine. I can regen and save and it still keeps the references. But if I close down AutoCAD and reopen the same file, the fields default to the current “Project A” information for both notes that were previously B & C, unless I have open all 3 sheet sets through SSM prior to opening the file with the notes.
The problem seems to be isolated to this project as I can create similar notes for other projects and maintain the results. I have tested it on 2016 and 2018 and on other users computers as well.
The only thing I can think of why it is happening maybe because this project was divided earlier this month. It was one DST file but we had to split out the sheets for separate submittals. I copied the dst file, renamed, then opened each up individually without any of the sheet files opened. I then removed the sheets from the DST file that it was no longer a part of. This allowed me to keep all sheet references later on that were already established in the plan set.
My first question, is there a fix or setting that keeps the references from defaulting back to the current sheet set?
Second, is there a better way to divide a sheet set/.dst file other than described above?
