@twbrown025 wrote:
I want to be able to have field to finish automatically draw in the interior building corner based off of the shots provided. Ideally it would be a line from point 302 that is perpendicular to the building face located as points 300 & 301.
I have messed around a little with the extend code but I can not get it to work without entering a dimension which I do not want to do. Any solutions?
I had to deal with that many times. The surveyor got lazy and never measured it. What I did was manually draw the right angle to get the distance from the lowest point (in your case #301). I then edited the point code to include the distance extension, then reprocessed the linework. That would ensure that any more processing would include the "fixed" point. If you manually edit the figure, but later on process the linework, your manual edit(s) cause duplicate figures.
It's one of the reasons I put an Idea to address issues like that, but Autodesk doesn't seem to care about survey anymore. Look at https://forums.autodesk.com/t5/civil-3d-ideas/survey-database-improvements/idc-p/7484340#M6389 to see that Autodesk "Accepted" my Survey Database improvements 4.5 years ago, but nothing was done. #2 on my list is the one I talked about in response to your question.
C3D 2022-2025
Windows 11
32GB RAM
