FGDB export user defined property
Hi, we're working on an easy way for the surveyors to export their resolved boundaries and some survey points to an arcGIS Pro project to track all the projects survey has done over the years in one visual place. For this to work though, it's gotta be easy for the surveyors or else they won't do it. the FGDB export function is great, however it does seem to export the user defined properties defined for each parcel. When I click "edit export settings", and click the drop down for "parcels", I only see the default options, not the multiple user defined properties which should be an option in "source attributes". Is this a bug/missing feature or am I missing something?
The above picture should also have the properties associated with this field shown below, JOB_NUM, DESCRIPTION, DWG_PATJ, DATE, CLIENT. But those are not an option for the download for some reason.
