feature line label disappears when the feature line Layer is turned off
sanetdikkumbura1950
sanetdikkumbura1950
When a feature line is labeled, the label disappears when the feature line is turned off. How do I turn off the feature line and display only the label?
ianjchap
Hi @sanetdikkumbura1950,
Sounds like you just need to get your labels onto a different layer. Have a look inside the label style, and setup a new layer for it to go on by default.
Ian Chapman
If you found this post useful, please Like the post.
If this post helped you successfully solve your problem, then click on the ACCEPT SOLUTION button.
sanetdikkumbura1950
@ianjchap Thank you.
