Feature Line from Alignment - Editable?
deltacoolguy
deltacoolguy
I have a feature line from alignment (and profile).  Easy enough to create.  The length of the alignment is 0+00 to 10+00.  I want this dynamic feature line to be only from 2+00 to 6+00, though.
I am presuming that there is no way to do this.  Is my presumption correct, or can someone lead me to the promised land?
It won't be a deal breaker if I can't do it, but it would be very helpful if I can.
Thanks.
Windows 10-64 Pro
8GB RAM (Home)
12GB RAM (Work)
AutoCAD Civil 3D 2019
Jeew-m
Dear Friend,
If the profile is a surface profile you can do the following.
Use create alignment from existing alignment option from the ribbon.
The you can create the new alignment from 2+00 to 6+00 along the old alignment.
Then add the surface profile to the alignment.
Finally create the feature line.
If you have a layout profile I hope you may have a look at superimposed profiles.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
copper.chadwick
Autodesk Support
Autodesk Support
@deltacoolguy,
Great question with a direct easy answer, unless of course the question is interpreted differently. First I have created a screencast demonstrating the activities required and behavior of @Jeew-m's response to your question.  @Jeew-m, thanks for your response to @deltacoolguy's post.
In this case (screencast seen below), I made the Feature Line from station 2+00 to 6+00 as in your example.
Could Feature Lines be made to be dynamic and change when the referenced alignment changes?
  • To this...I don't believe there is a way to make it dynamically linked and managed through the geometry of the referenced alignment.
That being said here is an leading article about:
Feature Lines
Topics in this section
Copper Chadwick
Designated Support Specialist
deltacoolguy
Thank you both for your solutions.  After I posted the question the parameters changed and I ended up doing something slightly different, but I will keep this in mind for the future.
Windows 10-64 Pro
8GB RAM (Home)
12GB RAM (Work)
