I have been messing with adding feature lines to my surface so I can get an accurate surface. But I'm having trouble seeing which line is picked after zooming to the chosen PI.
After zooming to the PI, it kind of deselects in the panorama
Is there a setting I can adjust to make the highlighted line a little easier to see? I have many PI's on these FL's and I need to double check my numbers quickly.
Solved by cselingo. Go to Solution.
I don't believe this can be changed. However you might want to look into using the quick elevation editor tool (command: QuickEditFeatureElevs) This tool lets you move along a feature line in modelspace displaying the PI elevations near the PIs & the grades when between PIs. One click lets you edit the displayed elevation or grade.
Thank you! This is much easier than what I was doing before. Still not an answer to the orig question so I'll wait a while before marking as solution.
