Feature line - convert elevation point to PI
atappanaQ2KLV
Message 1 of 10
atappanaQ2KLV
Does anyone know of a lisp that will do this? We are setting feature line elevations to 0 and exploding them to get polylines but elevation points are not shown as a vertex in the polyline after we explode.
Replies (9)
Message 2 of 10
BrianHailey
Message 3 of 10
joesalveson
I think the lisp routine, "SurveyFigureTo2dPolylinues" from another post I read will do what your asking.
Message 4 of 10
atappanaQ2KLV
I tried that one but it simply exploded the feature line and converted it from a 3d polyline a 2d polyline. With that operation it does not make elevation points to PIs and they are lost. I need to have a vertex on the poly line at every elevation point. Appreciate the response!
Message 5 of 10
Jeff_M
@atappanaQ2KLV attached is a small lisp that will convert Elevation points on a featureline to PI points.
Jeff_M, also a frequent Swamper
Message 6 of 10
atappanaQ2KLV
Thanks so much Jeff. If you're in KC some time let me know and I'll get you a beer.
Message 7 of 10
mjarour
Observer
Observer
works perfect for me
Message 8 of 10
forrestrike
@Jeff_M any chance you have a lisp that will convert feature line PIs to elevation points? It seems like it could be a nice work around for removing PIs without losing the feature line geometry (convert PIs to elevation points, delete the elevation points).
Thanks!
Message 9 of 10
jmayo-EE
It sounds like the PI's you want to remove are colinear. In that case try the Weed Features command.
John
John Mayo
Message 10 of 10
Jeff_M
@forrestrike attached is a lisp that replaces colinear PI's with Elevation points.
@jmayo-EE does weeding do that? If so, I haven't found a way to set the options up properly.
