Feater Line Vetex Highlights
Yehoshua.Shore
Yehoshua.Shore
When editing the vertex of a feature line, the vertex is hilighted in a green triagle. Is there a way to stop this triangle from scaling with the current level of zoom, and set my own scale for them? I am often unable to see the highlited vertex becouse they are too small.
tcorey
Those glyphs only display when you are editing the feature line through commands. If you just select the feature line on the screen, it will only show grips, your Cant See image.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Yehoshua.Shore
Thank you for answering.
Yes I am aware of that. In both pictures, the feature line is being modified using the Elevation Editor. When I’m zoomed out selecting a vertex in elevation editor, the vertex is indeed highlighted, but it’s too small to see at the scales I need to work in, where my vertices may be kilometers apart.
cwr-pae
As a workaround, select the FL and enter edit mode, zoom out and select the vertex, then zoom in using the mouse wheel. The triangles should be a larger, sized relative to the zoom when they were selected.
EDIT: also if you deselect the fl after entering edit mode the grip highlights will disapear leaving just the edit glyph triangle.
Yehoshua.Shore
Thank you so much for your help, but I am looking for a way to edit the display size of the glyph without having to play around with the zoom.
