Good afternoon,
Since few days ago when I try to analyze watersheds over surfaces in Civil3D, the programme crashes and the attached error is displayed.
I have tried to trim the surface in order to reduce the analysis performance, but the program still crashes.
Any idea of waht´s happening and how I can solve this annoying trouble?
Thanks for your help!
I assume you're running all the latest service packs? Does it happen on all surfaces or just this one?
Steve Hill,Civil Designer / .NET Developer / AutoCAD and AutoCAD Civil 3D Certified Professional
http://redtransitconsultants.com/
Autodesk Exchange Store
Twitter | LinkedIn | YouTube
Hi redtransit,
Yes, I have installed the two service packs and it always happen no matter what kind of surface I´m using. Sometimes if the surface is below (1 ha-2.5 acres), the results are displayed, but when trying to edit the surface style in order to show the watershed areas, Civil3D freezes.
My best regards!
Antonio Carmona
Aeronautical Engineer, airport designer.
Ineco, Transport Engineering and Consultancy
What heppend with this problem? I have the same problem. I don't know about my service packs, but I will try to check them.
